Home » Audio » Speaker » Your favourite 1'' compression driver!
Your favourite 1'' compression driver! [message #16741] Sun, 25 July 2004 14:29 Go to next message
Magnus is currently offline  Magnus
I am in the early planning stage of a new home system and on the hunt for a good 1'' compression driver for use between say 2k-9k. The top octave will be handled by a JBL 2405 slot so HF response isn't much of an issue. What are your suggestions, both price/performance and performance alone? These are the drivers I have been looking at so far. I would really be thankful if anybody could comment on the stuff from Beyma since I can get them at a really good price.
JBL 2426
B&C DE25
Beyma CP350/Ti
Beyma CP380/M
Beyma CP385/Nd
And of course Eminence PSD2002, P. Audio stuff etc.
/Magnus
Re: Your favourite 1'' compression driver! [message #16742 is a reply to message #16741] Sun, 25 July 2004 19:13 Go to previous messageGo to next message
Since you're going to use the JBL 2405, I'd probably go with the JBL 2426 as my favorite. It's a great sounding tweeter. For best performance for the cost, I like the Eminence PSD2002. I really like that part, especially for its extended frequency response. That won't matter much to you since you'll have a super tweeter. But nevertheless, I think it is a good tweeter, especially for its low cost.
PSD2002 [message #16744 is a reply to message #16742] Mon, 26 July 2004 10:34 Go to previous messageGo to next message
Wayne,
I have only heard the PSD2002 once but it sure sounded pretty nice. And I do not doubt that the price/performance ratio of that driver is the best out there (piezos apart). But I might be willing to spend a little more to get an even better driver. As I said, I can get the Beyma's pretty cheap and the JBL 2426 even cheaper. (Second hand, that is. JBL pro parts are just too spendy over here. A 2226 for example retails for around USD $650 a piece!). I am leaning towards a wooden horn for the 1'' driver, your conical Pi horn for the mids and a JBL 2226 at the bottom.
/Magnus
Used JBL 2426 [message #16745 is a reply to message #16744] Mon, 26 July 2004 10:54 Go to previous messageGo to next message
Be careful of used JBL 2426's, especially if they are inexpensive. There are cheap diaphragms available for them that don't sound very good. The price of a new 2426 is about the same as a 2226, and both hold their resale value very well when in good condition. So if you find 2426's for sale cheap, they probably don't have genuine JBL diaphragms.
Re: Used JBL 2426 [message #16747 is a reply to message #16745] Mon, 26 July 2004 11:18 Go to previous messageGo to next message
Thanks for that warning! And I guess it would be almost impossible to tell a genuine JBL diaphragm from cheap 3rd party vendor or????
Now and then they pop up here for around $350-500 a pair second hand.
/Magnus
Re: Used JBL 2426 [message #16748 is a reply to message #16747] Mon, 26 July 2004 11:22 Go to previous message
You can tell the difference by visual inspection. But that requires you to open them up.
Previous Topic: choices, choices
Next Topic: Very nice cabinet work for Fostex 168
Current Time: Mon Nov 16 05:26:18 CST 2026
