Home » Audio » Speaker » CHoices! (basshorns)
CHoices! (basshorns) [message #16505] Mon, 17 May 2004 08:25 Go to next message
Hi all!
Big dilemma!
firstof all may i say,that the small graph makes the differences look small,when i think it infact is large differences here.
i have 2 horns designed and cad'd
Im not particularly bothered about superlows-because i know these 32hz notes only appear on SOME music,so the practicality is lower(eg royaldevice.com overkill)
i know il be happy with the 37hz horn-but if i build that horn,and then could i then think,i shudve gone the deepest i couldve,29hz?
Re: CHoices! (basshorns) [message #16507 is a reply to message #16505] Mon, 17 May 2004 17:13 Go to previous message
Yeah, the longer horn gives you about 10Hz more extension, a noticeable difference. It's shorter too, so you could stack 'em nicely if you wanted to. I think that's the one I like best.
Previous Topic: Playing with Mcbean
Next Topic: Speaker Question
Current Time: Mon Nov 16 05:26:30 CST 2026
