Home » Audio » Speaker » Eminence Beta 8CX
Eminence Beta 8CX [message #16419] Sun, 02 May 2004 03:24 Go to next message
Has anyone used the Eminence Beta 8CX before with the reccomended APT-50 supertweeter? What's the quality like of both these components?
The Beta 8CX datasheet says its 89mm deep, but is it more deeper with the APT50 fitted or it is the same?
Does this driver 'sound' 'better' than a normal low eff commerical driver (for fullrange use)?
Might be cool to try a pair in a car.
Re: Eminence Beta 8CX [message #16420 is a reply to message #16419] Sun, 02 May 2004 05:21 Go to previous messageGo to next message
I'll bet you're right - I'll bet it does sound good in a car. Probably be great with a subwoofer for home use too. Adire Audio makes speakers based on Eminence Beta coaxials and a version of the APT-50 tweeter.
Re: Eminence Beta 8CX [message #16422 is a reply to message #16419] Mon, 03 May 2004 05:43 Go to previous messageGo to next message
John Sheerin is currently offline  John Sheerin
Screwing on the APT adds about 1-7/8".
John
Re: Eminence Beta 8CX [message #16424 is a reply to message #16422] Mon, 03 May 2004 17:47 Go to previous messageGo to next message
Thanks John.
Could the PSD2002-S also be screwed onto an 8CX? Or do you need to find 'mini' compression drivers?
I guess that would also add more depth if it can be done.
Adrian
Re: Eminence Beta 8CX [message #16425 is a reply to message #16424] Tue, 04 May 2004 12:40 Go to previous message
Yes, that would also work. It would add about 2-1/8" to the driver. However, I think I'd prefer the APT.
John
Previous Topic: ALON I Crossover
Next Topic: To horn or not to horn?
Current Time: Mon Nov 16 05:26:46 CST 2026
