Home » Audio » Speaker » Yet Another HORNRESP Question....
Yet Another HORNRESP Question.... [message #16292] Fri, 02 April 2004 08:39 Go to next message
VRC - is that net (volume minus driver displacement) or gross? In other words does the program assume a rule-of-thimb driver displacement volume based on Sd?
Thanks
Re: Yet Another HORNRESP Question.... [message #16293 is a reply to message #16292] Fri, 02 April 2004 08:55 Go to previous messageGo to next message
That's net. You must enter the actual throat chamber volume. This is usually the volume between the cone and the mounting plate for cone-driven horns. Also include the volume made from the cross-section area of the mounting plate and its thickness, although most times this is small enough it doesn't matter much.
Re: Subwoofer Horn [message #16295 is a reply to message #16293] Fri, 02 April 2004 09:49 Go to previous messageGo to next message
isnt Vrc the volume of the REAR chamber not the front wayne?
but the Vtc, of the front chamber ,thats what you described correctly
Re: Subwoofer Horn [message #16296 is a reply to message #16295] Fri, 02 April 2004 10:12 Go to previous messageGo to next message
Of course, you're right Mike. Jeez, I don't know how I misread that. But the volume entered should still be NET actual volume, and the displacement from stuff inside the chamber (like the driver itself) should be removed.
Thanks guys! [message #16298 is a reply to message #16296] Fri, 02 April 2004 11:25 Go to previous message
I assumed as much, but I thought I'd make sure.
Thanks again.
Previous Topic: Magnet structures
Next Topic: Aluminum foil used as a transducer
Current Time: Mon Nov 16 05:27:52 CST 2026
