Home » Audio » General » Tripp Lite go no go
Tripp Lite go no go [message #1409] Fri, 01 April 2005 05:23 Go to next message
Clip pen pull... is currently offline  Clip pen pull...
I am having clean power problems. Every year I move to some different 3rd World Country where the power coming out of the wall outlet is predictably bad. The Amp that I am currently using is doing a brilliant job but is hampered by the disastrous power here in central China. I am doing research in a conditioner/power source solution for my current Amp, which has the capability of drawing approx 2400 watts. I am wondering if anyone has heard of someone using a Tripp Lite Online UPS AC-DC-AC power plant like for example SUINT3000RTXL3U which seems to be a flexible conditioner and regulator. I intend to either replace the cooling fan with a run silent or move this product to another room for the noise I know it will make. It just seems that all the "audiophile solutions are laughably over priced and incapable. Home is where the Marines send me.
Re: Tripp Lite go no go [message #1412 is a reply to message #1409] Fri, 01 April 2005 05:41 Go to previous messageGo to next message
Check the waveshape coming out when the batteries are running. The expensive converters make nice clean power but some inexpensive converters put out a pretty grungy signal.
In fact, I ran one when I was overseas and connected a barrier strip with built-in surge protection. The converter in the UPS generated such high spikes, the protection MOVs in the barrier strip tried to clamp them and shorted out. I removed the shorted MOVs and converted the barrier strip into an unprotected unit. The UPS had been damaged but a second one worked fine, so I was able to run equipment with it even when power failed.
The point of all this is that inexpensive UPS units make a signal that is so marginal it actually damages equipment with surge protectors built in. So be careful and check the signal before using it with anything delicate or expensive.
Re: Tripp Lite go no go [message #1416 is a reply to message #1412] Fri, 01 April 2005 05:52 Go to previous message
I guess I will do some investigation in their claims of "pure sine wave AC output" 1500 USD is not that cheap although the name Tripplite sure is. Thanks for the fast response
Previous Topic: Great Plains Audiofest - INFO
Next Topic: $125,000 Audio Note speakers at GPAF?
Current Time: Wed Nov 25 02:31:12 CST 2026
