Home » Audio » Speaker » vintage or new? Polk or ?
vintage or new? Polk or ? [message #15442] Thu, 04 January 2007 18:11 Go to next message
Buzz is currently offline  Buzz
I am putting together a system to play old 33 1/3 and would like to know if I should buy old vintage like Polk 10 or can you get a rich full sound on the new speakers. Any suggestion for a low budget? thanks, Buzz
Re: vintage or new? Polk or ? [message #15443 is a reply to message #15442] Wed, 10 January 2007 15:27 Go to previous messageGo to next message
MWG is currently offline  MWG
You specifically mentioned budget so vintage is the way to go in your case I believe. You can get higher end vintage speakers for a lot less money than equal quality made today.
Re: vintage or new? Polk or ? [message #15444 is a reply to message #15443] Wed, 10 January 2007 17:13 Go to previous message
Thanks for the advice. In my search I found a pair of Polk SDA 2b's. I hope I made a good choice. I also bought a Pioneer SX750 and a CP1033a turntable. Now I'm looking for a reel to reel. Thanks for the response, Buzz
Previous Topic: Semi out of place question.
Next Topic: Damaged Wizzer Cone
Current Time: Mon Nov 16 06:50:26 CST 2026
