Home » Audio » Speaker » Need help with my first build project
Need help with my first build project [message #15256] Tue, 11 April 2006 19:34 Go to next message
Faust is currently offline  Faust
Hi, I found a little driver that I'm interested in (Dayton Quatro 8"), and Parts Express even has recommended enclosure plans for it. I am planning on building the vented enclosure plan found here:
http://www.partsexpress.com/pdf/295-545%20vented.pdf
Looks like a good and easy first build. However, I have a couple of questions. First, how the heck do you fit an 11" tube into a 10" cube. Am I missing something here? Second, can I believe the specs listed on page 3 of the pdf (specifically the custom amplitude response)? If the specs are correct, this is an awesome little box.
I'm glad I found audioroundtable. You folks have great forum here.
Thanks, Faust
Re: Need help with my first build project [message #15257 is a reply to message #15256] Wed, 12 April 2006 04:58 Go to previous messageGo to next message
If the published specs are correct, the 10" box is too small. Make it an 11" cube and then you can use a 6" port. F3 should be ~35 Hz. Better yet, go for an EBS alignment of say 12.5"^3 and a 6" port for an F3 of ~28.
You might also ask why PE show SPL@300 watts for a driver specified @ Pe=150w.
Bob
Re: Need help with my first build project [message #15258 is a reply to message #15257] Wed, 12 April 2006 10:33 Go to previous message
Thanks Bob. I think I'll try the EBS alignment idea. I just want to be sure about the vent on this new design. Would the vent opening be 2" (2"x12.5"x6"deep)?
Also, I asked Parts Express about the listed specs and here is the reply:
"Pe is actually max power, not RMS. THis is why this was shown this way. the driver is specified as 150w RMS and 300 MAX."
Previous Topic: Dynaco A25
Next Topic: Some simple Array questions
Current Time: Mon Nov 16 06:36:33 CST 2026
