Home » Audio » Speaker » Whats the diffrents? In these driver units?
Whats the diffrents? In these driver units? [message #15082] Thu, 11 August 2005 14:20 Go to next message
djm is currently offline  djm
Hi I am looking to use scan speak or usher speakers. They both look
the same but, the scan speak looks like it has more extras on it.
Does this make it a better driver? Are they going to up date there
carbon fiber drivers soon. Which is a better driver? Thanks jm
Re: Whats the diffrents? In these driver units? [message #15083 is a reply to message #15082] Thu, 11 August 2005 16:04 Go to previous messageGo to next message
Can you be more specific? What drivers do you mean and can you post the measured response? How are they used? Two way/three way? What size are they, 8" 12"?
Re: Whats the diffrents? In these driver units? [message #15087 is a reply to message #15083] Fri, 12 August 2005 06:45 Go to previous messageGo to next message
Yes this is the model number for the scan speak driver it is
18w/8545k a 7 inch carbon fiber/paper woofer. The usher is
8945a also a carbon fiber/paper woofer. The price diffrence is
$ 38.85. Is it really a diffrence in sound and extra bells and things
like for the scan speak sd-1 r3,kapton former a grasshopper castframe
does this really make a diffrence or is it just adding to the driver
to make it look like your getting more? The usher not to much going
on over there. A lot of people think it is a newer design of the same
driver. I am goin to use them in a ported box a 2 way. All for music
only. I have a hometheater set up so it will not be used for that.
I am looking at getting the woofer testerr 2 from parts express.
It seems to work really well and this is my 3rd speaker I am building
and want to get it right. Well if you want to know more just e-mail
me and I will try to get you the best answer I can. Thanks jm
Re: Whats the diffrents? In these driver units? [message #15088 is a reply to message #15087] Mon, 15 August 2005 19:37 Go to previous message
I don't have first hand experience with the drivers but you may find this article helpful.
Previous Topic: CSS FR125s project webpage
Next Topic: Koss 1A's
Current Time: Mon Nov 16 06:19:40 CST 2026
