Home » Audio » Speaker » JBL 2242H
JBL 2242H [message #14752] Sat, 23 October 2004 17:27 Go to next message
Lightnin is currently offline  Lightnin
Hey ya'll.I've got some JBL SR4719X cabs and I want to put some 2242H drivers in them.Do you think they will work well compared to the 2241H's that were in there.Any information would be greatly appreciated.
Re: JBL 2242H [message #14753 is a reply to message #14752] Sun, 24 October 2004 02:51 Go to previous messageGo to next message
That'll do very nicely. Very nicely indeed.
Re: JBL 2242H [message #14754 is a reply to message #14753] Sun, 24 October 2004 08:30 Go to previous messageGo to next message
Thanks for the words Wayne.The 2241 has a Qts of .4 and the 2242 has a Qts of.28.2242 X-max is 9mm and 2241 X-max is 7.6.Other than the fact that the 2242 will take 800W instead of 600W and is 1db more sensitive.The main difference seems to be the Qts thing.Do you think I should make any modifications to the cabs or just leave them alone?Are there any drawbacks to this switch.And why isn't it a more common practice?Money? Thanks a bunch.....Lightnin
Re: JBL 2242H [message #14755 is a reply to message #14754] Sun, 24 October 2004 09:14 Go to previous messageGo to next message
The JBL 2242 works pretty well in cabinets designed for the 2241. Their electro-mechanical parameters are different, but they are each tuned to work well in 10ft3 cabinets tuned to 35Hz. They actually have a pretty wide range of good alignments, from basically 6ft3 to 12ft3 and from 30Hz to 40Hz tuning. This broad range makes them relatively insensitive to cabinet tuning and very tolerant of parameter shifts over their operating range. Both the JBL 2241 and the 2242 are robust high-quality designs that offer consistent performance over a wide range of conditions.
Re: JBL 2242H [message #14756 is a reply to message #14755] Sun, 24 October 2004 13:09 Go to previous messageGo to next message
Thanks Wayne.I feel more confident now.So I can get on with my project.Geting more sound and hauling less cabs. Lightnin
Re: JBL 2243hpl [message #14757 is a reply to message #14756] Wed, 27 October 2004 12:05 Go to previous messageGo to next message
gazzamongo is currently offline  gazzamongo
anyone any expeience with this driver and in what applications?(picked one up cheap)
it's from the jbl soundpower series
how do they compare to the other two mentioned in terms of sound quality
cheers
gazza
Re: JBL 2243hpl [message #14758 is a reply to message #14757] Wed, 27 October 2004 14:24 Go to previous message
Cool! You won that speaker! Great price too - You can recone it and make it good as new.
Did you ever write to JBL and ask what recone kit you should use?
Previous Topic: Legend 875
Next Topic: Jim's talk at DIY dayton
Current Time: Mon Nov 16 05:44:06 CST 2026
