Home » Audio » Speaker » Bandpass subs
Bandpass subs [message #14716] Thu, 16 September 2004 12:19 Go to next message
Ranier is currently offline  Ranier
What are the advantages and disadvantages of bandpass subs? Do they add gain or do they offer greater bass extension or both? I am looking at some options right now.
Ranier
Re: Bandpass subs [message #14717 is a reply to message #14716] Fri, 17 September 2004 08:02 Go to previous messageGo to next message
Two advantages. One, you don't have to do as much electronic filtering to remove unwanted high-frequencies from the passband. Two, the added mass loading of the driver by the second chamber lowers the potential passband frequency. It is possible to tune a bandpass box to achieve some gain, but so doing also narrows the passband, so that is not the usual reason for using a bandpass box.
One more advantage... [message #14724 is a reply to message #14716] Tue, 28 September 2004 08:14 Go to previous message
..is the reduced diaphragm excursion, maintained over almost the entire bandpass of the sub. This also mean you can EQ a bandpass sub in the bottom end. I use a BP-sub (DIY) with a Peerless 10" driver in a box of ~80 liters (active volume) - it goes from 28Hz to 75Hz (no EQ'ing), -3dB.
Previous Topic: fostex design search results
Next Topic: fostex and speaker cables
Current Time: Mon Nov 16 05:44:56 CST 2026
