Home » Audio » Speaker » ALON I Crossover
ALON I Crossover [message #14586] Sun, 25 April 2004 14:29 Go to next message
Ryan is currently offline  Ryan
I plan to improve ALON I crossover network using high quality parts. All suggestion appeciated!!!
Re: ALON I Crossover [message #14587 is a reply to message #14586] Sun, 25 April 2004 15:39 Go to previous messageGo to next message
You can usually improve a crossover by replacing electrolytics with polypropylene caps. Use film/foil caps where possible and metalized film for larger values. I'm sure that resistors are already non-inductive types but you might check them to be sure. Some folks like to upgrade their coils too but I find the biggest improvement comes from replacement of electrolytic capacitors.
What exactly are you hoping to gain by this upgrade?
Re: ALON I Crossover [message #14588 is a reply to message #14587] Sun, 25 April 2004 20:48 Go to previous messageGo to next message
The speakers need to be reconed so I am making this overhaul project from them.
Re: ALON I Crossover [message #14589 is a reply to message #14588] Thu, 29 April 2004 19:43 Go to previous messageGo to next message
You need to contact Carl, he has made several changes to that speaker and will be able to tell you what values to use to get the sound you want, mucho experiments with that xover.
Re: ALON I Crossover [message #14590 is a reply to message #14589] Sun, 02 May 2004 12:40 Go to previous message
I will do this certainly.
Previous Topic: Guess what kind of speakers I built this week?
Next Topic: Eminence Beta 8CX
Current Time: Mon Nov 16 05:27:47 CST 2026
