Home » Audio » Source » pitch control problem
pitch control problem [message #13434] Tue, 17 July 2007 15:01 Go to next message
erix is currently offline  erix
I have 2 GEMINI TT-04 TURNTABLES.MY PROBLEM IS WITH PITCH CONTROL ON 1 TURNTABLE BECAUSE SOUND AND MY BPM COUNTER SHOWING ME DIFFERENT BPM ON 2 TURNTABLES WITH SAME RECORDS..BPM IS DIFFERENT ON 1 TURNTABLE IS TOO SLOW AND WHEN I CHANGING UP TO 10%. PITCH ON 8 % ALMOST 10 MUSIC JUMPING FROM 136 BPM. - 150 BPM VERY FAST AND SHUDNT B LIKE THIS.THANKS FOR QUICK ANSWER AND I HOPE I TRY IT FIX FAST .
Re: pitch control problem [message #13435 is a reply to message #13434] Wed, 18 July 2007 14:49 Go to previous messageGo to next message
If your turntable is servo controlled, then the problem is likely within the PLL control circuit. Slow speeds are sometimes the result of a simple mechanical problem but fast speed usually means the servo circuit is bad. You may have to replace the servo circuit to see if that fixes it.
Re: pitch control problem [message #13438 is a reply to message #13435] Wed, 18 July 2007 17:36 Go to previous message
how i would do that? where i can buy this??
Previous Topic: Good vinyl score
Next Topic: Warped sounding: not the album, platter or belt...what is it??
Current Time: Thu Nov 05 16:49:14 CST 2026
