| Is switching from carpets to hardwood floors actually worth it? [message #99406] |
Mon, 11 May 2026 10:44  |
Bercle
Messages: 92 Registered: December 2025
Viscount |
What has been your experience with hardwood floors in a listening room? What I currently have right now is carpet, and it seems it makes the room feel quiet and the music not sounding the way that I want it to sound. In the beginning, I felt it was fine since I didn't have to get echo, but I don't feel that satisfied and have been thinking of switching to hardwood floors.
Is there anyone who's tried using both? Do you think hardwood floors with good treatment are better than using just carpet, or should I keep managing this?
| Re: Is switching from carpets to hardwood floors actually worth it? [message #99440 is a reply to message #99406] |
Mon, 25 May 2026 20:18   |
Clint
Messages: 68 Registered: December 2025
Viscount |
I have been opportune to make use of both carpets and hardwood in the listening. For that reason, I get how you are feeling about the whole thing.
When I had carpet in the room, it brought about zero echo and a dead-quiet room, and the feeling was good at the beginning, but certain things weren't cool with it. The vocal sounded dull, for example, and the energy in the songs that I listened to weren't fantastic.
I would say that Hardwood is better because when I got them last four years, placing a think rug between the speakers and I, some absorption panels on the first reflection points and bass traps in the corners of the rooms made the songs sound far more better than when I made use of carpets.
So, I will always pick Hardwood because I like better sounds when I listen to songs in the listening room. You can stick to your carpets if you are pretty fine with calm sounds.
| Re: Is switching from carpets to hardwood floors actually worth it? [message #99507 is a reply to message #99440] |
Sat, 13 June 2026 13:11   |
Prince
Messages: 121 Registered: September 2025
Master |
Clint wrote on Mon, 25 May 2026 20:18I have been opportune to make use of both carpets and hardwood in the listening. For that reason, I get how you are feeling about the whole thing.
Anyone who is not so bothered about the sound quality of songs or movies that they are watching should get a carpet because that is quite affordable. However, I'd advise anyone keen on improve the sound quality of their music gears to switch to hardwood. The difference is certainly clear.
| Re: Is switching from carpets to hardwood floors actually worth it? [message #99892 is a reply to message #99890] |
Wed, 28 October 2026 21:17  |
gofar99
Messages: 2065 Registered: May 2010 Location: Southern Arizona
Illuminati (5th Degree) |
Hi, My sense is that the popcorn probably makes a small difference to the very top end. Since the room is really live and reflecting before the various treatments any help is useful if only in small doses. IMO the popcorn is better than a bare plaster board ceiling as it would be reflective at all frequencies. Since the ESLs are really "fast" and respond well up to 22K HZ and have a slight rake of about 10-15 degrees the high frequency signal reflections would likely be awful. It brings up a whole new subject of the difference in how more conventional speakers "beam" the sound vs bi directional ones that intentionally reflect the sound. I love them...but they are not for everyone.
