| Request for Four Pi plan [message #99254] |
Tue, 03 March 2026 06:43  |
amigo
Messages: 8 Registered: March 2026
Esquire |
Hi, Wayne,
Thank you for your kind arrangement. I wish to build a four Pi speaker here in Korea based on your kit. Could you please send me the plan for four Pi and three Pi Sub?
Best regards, Chang-Hee
| Re: Request for Four Pi plan [message #99264 is a reply to message #99259] |
Thu, 05 March 2026 04:46   |
amigo
Esquire |
Hi, Wayne,
I could find the drivers, B&C DE250 and JBL2226HPL, here locally, and then I may just place the order only for the horn and the XO from your Parts and Options page. How can I ask Pi logo decal and Is the XO of fully assembled or as discrete components way?
Another question is the local distributor told me that JBL 2226H is not available but 2226HPL is OK and both are 'almost(?)' same drivers. But I am afraid whether thery are exactly same models. Would you mind giving me some hints on this?
One more question; When planning to attach a grille to the front of the four Pi speaker enclosures, it seems like the speaker box will have a slightly more bordered area than the front plate for shape reasons, and there will also be a frame for attaching the grille cloth, so I wonder if these will interfere with sound radiation from the front of the speakers. What precautions should I take?
Regards, Chang-Hee
| Re: Request for Four Pi plan [message #99265 is a reply to message #99264] |
Thu, 05 March 2026 09:21   |
We sell crossovers fully assembled and we also sell just the blank board. When buying fully assembled, you'll notice there are options for component selections. When buying the unpopulated raw printed circuit board, you obtain your own passive components and assemble it yourself.
The entry-level assembled crossover is very good. It includes 18gu pure-copper air-core coils, polypropylene film capacitors and non-inductive resistors. All brands are of high quality.
Upgrades available include larger 15gu coils, which is worthwhile, especially if you consider running a tube amp. Various brands of capacitors can be selected, and Mills resistors can be selected as well. Choosing any of those is largely buyer-specific, as they are all good brands making high quality components.
As for the drivers, make sure the compression driver is the 8Ω polyimide version, part number DE250-8. The JBL 2226HPL is a fine substitute for the 2226H, as the only difference is cosmetic. The 2226H is packaged and sold as a raw driver, whereas the 2226HPL is intended to be installed in a cabinet.
About grilles, they are often a "necessary evil" - often made more important because of pets, young children or other "hazards." Then again, sometimes they are an aesthetic decision. Some speakers with grilles look fantastic. But even the most acoustically transparent material isn't truly transparent. Most don't color the sound too bad, but they do have a slight effect.
My suggestion is to make grilles removable so you can have "the best of both worlds." The traditional way to do that was with mounting posts or Velcro. Another way to do it that I really like is with magnets. Small cylindrical neodymium magnets can be embedded in the baffle with mates embedded in the grille frame. Simply drill a hole and press in the magnet, adding a dab of glue. Do this step ahead of veneering and when the grilles are removed, the main cabinet has no visible grille mounts.
