Home » Audio » Source » Lenco L65 hums only when playing
Lenco L65 hums only when playing [message #13249] Mon, 15 January 2007 08:38 Go to next message
Peter is currently offline  Peter
I have a Lenco L65 with Stanton 500 cartridge of the old days, and whilst playing, it produces a significant hum. This means it hums while the needle is on the record (or on my finger) AND the motor is switched on.
I've opened it, and everything seemed normal (as far as I could see - the connections inside the arm bearing are impossible to see). When I try to wire the arm with the chassis, nothing changes.
As I could read on Graham Slee's site, there is a tag from my left channel ground connected to the chassis of the cartridge. According to Slee, it could give a hum loop when the arm is well earthed. I didn't remove the tag as it has always been there, probably since my grandpa bought it back in the seventies or sixties.
Please, help!
Thanks
Re: Lenco L65 hums only when playing [message #13250 is a reply to message #13249] Mon, 15 January 2007 16:51 Go to previous messageGo to next message
Just wondering if you have tried the most basic test, which is to reverse the AC power plug in the socket.
Dave
Re: Lenco L65 hums only when playing [message #13251 is a reply to message #13250] Tue, 16 January 2007 01:28 Go to previous messageGo to next message
I tried, it doesn't change anything...
Re: Lenco L65 hums only when playing [message #13252 is a reply to message #13251] Tue, 23 January 2007 03:46 Go to previous messageGo to next message
If you're interested, you can help me at the colleagues of
Re: Lenco L65 hums only when playing [message #13253 is a reply to message #13252] Tue, 23 January 2007 10:20 Go to previous message
I think most will tell you to check ground and connections. You probably have an open or partially open in one of the signal or ground lines.
Previous Topic: need advise on turntable to keep
Next Topic: Denon DP-37F
Current Time: Wed Oct 21 04:14:22 CDT 2026
