Home » Audio » Silicon Valley » Power FETs
Power FETs [message #98057] Sat, 26 October 2024 14:58 Go to next message
Hi, has anyone used N channel enhancement MOSFETS as a CCS?
Re: Power FETs [message #98059 is a reply to message #98057] Sun, 27 October 2024 09:28 Go to previous messageGo to next message
I haven't, but that does sound like a good idea. Seems like I remember seeing some schematics for just such a thing. Please do report back what you find if you experiment with that.
I've only designed with traditional power transistors, for high-current outputs, high-voltage outputs or a combination of the two. Those applications are kind of simple. I drive an automobile spark plug coil with a PNP power transistor, for example. That's basically the same approach as using one for a flyback transformer.
Re: Power FETs [message #98061 is a reply to message #98059] Sun, 27 October 2024 20:24 Go to previous messageGo to next message
HI I have seen plenty using depletion MOSFETs, but none with enhancement ones. I have lots of the the enhancement ones and the others are still a few $$ to buy. Another thing I noticed was that the depletion ones have relatively high Rd-s compared to the enhancement ones roughly a 10 to 1 ratio. It would seem to make the enhancement ones better as a CCS.
Re: Power FETs [message #99729 is a reply to message #98057] Sat, 22 August 2026 21:51 Go to previous message
Hank is currently offline  Hank
The thing is that I've made use of N channel enhancement mosfets as a CSS a couple of times when I ran different projects. The last one that I did was when I constructed one for powering LEDs in a test circuit. It worked pretty well when I was able to fit the resistor value correctly.
The word of advice that I would give is for you to ensure that you make use of quality parts in your setup because there are chances that the  current will fluctuate sometimes. Another thing that I always did was watch the heat and match closely because not doing so can make a mess of the whole thing.
Aside from these minor issues,  I would say the N-channel enhancement MOSFETs does a good job for low-cost constant current and I've had a few successes using it in the past.
Previous Topic: What's your preferred solid-state amp now?
Next Topic: Thinking about the Vitus SS-103, is it worth the price?
Current Time: Sat Nov 21 02:22:48 CST 2026
