Home » Sponsored » Pi Speakers » Barkyard BBQ Drive-in Theater Speakers....
Barkyard BBQ Drive-in Theater Speakers.... [message #97787] Fri, 21 June 2024 10:58 Go to next message
Tronographic is currently offline  Tronographic
So, We have been showing movies in our Brooklyn back yard since before 2020... and during lockdown we started showing double-features on summers weekends and all of October we show horror movies.. On a screen in our garden with friends and a little fire pit for S'mores... It's amazing.
The weak link has always been the sound system... the first year I set up some old Yamaha stereo speakers with my Paramour amps (not bad), those speakers went away and I eventually attached a pair of Realistic Maximus 7s on either side of the screen and powered with a Parts Express digital amp so I could use the Bluetooth in my Bluray player to cut down on cabling outside... Stereo spread is good, but the little 7s are underwhelming... I think I want more bass and to have a set I can plop on the ground on movie nights but keep stored in the basement or in a shed when not in use.
Now I want to build either a pair of OnePi or TwoPi speakers and possibly integrate a BT receiver/amp into both or one... I also plan to wrap them in tolex and make covers for them so they can be stored in less-than ideal storage situation...
So I could use some ideas.
I have an older set of plans for the TwoPis kicking around (pre Vifa_DX25)... but I'm thinking the OnePis might also be good to consider. 5.1 might be an eventual set up, but for now stereo it preferred.
I could use some current plans for both the One and Two PIs...
Thanks guys.
Re: Barkyard BBQ Drive-in Theater Speakers.... [message #97788 is a reply to message #97787] Fri, 21 June 2024 12:30 Go to previous messageGo to next message
I would suggest two Pi tower speakers because they provide deeper bass.
Or you could run either of the studio models - one Pi or two Pi - and add subs.
Still better would be four Pi mains with subs.
Any way you do it, use Baltic Birch rather than MDF. I prefer MDF when indoors, but Baltic Birch when used outdoors or when the speakers might e moved often.
Re: Barkyard BBQ Drive-in Theater Speakers.... [message #97792 is a reply to message #97788] Sun, 23 June 2024 13:45 Go to previous messageGo to next message
Thanks Wayne!
I have some high-quality Finland birch (multi-ply) I'm using, It's also marine-grade and void free... been using this product for years in my speaker builds... stuff is getting prohibitively expensive to use though.
I could use current plans for the One, Two and Two Towers... all my old files are long gone. Thanks!
I have Four Pi plans and some parts I've been sitting on for years... I hope to eventually make a pair and use them for my backyard parties. It's not a huge space so I might not need much more than the Two-PIs... but I can imagine the dynamics would be much better for movies with the Fours.
Re: Barkyard BBQ Drive-in Theater Speakers.... [message #97795 is a reply to message #97792] Sun, 23 June 2024 16:52 Go to previous message
You've got mail!
Previous Topic: It's getting to be subwoofer time.
Next Topic: Two PI depth adjustment
Current Time: Sat Nov 28 14:19:32 CST 2026
