Home » Audio » Source » Turntable problem
Turntable problem [message #13086] Fri, 15 September 2006 18:26 Go to next message
AnonymousFan12346 is currently offline  AnonymousFan12346
I have a very nice Technics turntable (from the 80s/late 70s most likely) that had a bit of a problem. It plays LPs and 45s perfectly fine, but it always lags. You know how the dots on the plate thing are supposed to stay in one place? Mine move around about every 3/4 second. I will take a video and post it later.
Re: Turntable problem [message #13087 is a reply to message #13086] Fri, 15 September 2006 21:14 Go to previous messageGo to next message
There are adjustments for the speed control. You must download the manual for the method.
Re: Turntable problem [message #13088 is a reply to message #13087] Sat, 16 September 2006 09:48 Go to previous messageGo to next message
Look for your manual on vinylengine.com, or one similar to it. Or do you mean adjusted all the way, its still wont stabilize? If that is the case, some minor repair is in order, not uncommon on a lot of older direct drive tables.
Russellc
Re: Turntable problem [message #13098 is a reply to message #13088] Wed, 20 September 2006 16:19 Go to previous message
Might be something as simple as needing lubrication.
Previous Topic: Bang & Olufsen TT
Next Topic: Funny how an .3 mV cart plays on a 44dB MM phono stage
Current Time: Thu Nov 05 23:45:55 CST 2026
