Home » Audio » Pro Sound » Piano Applications on the Phone
Piano Applications on the Phone [message #95526] Sat, 16 April 2022 06:12 Go to next message
Beck is currently offline  Beck
Does playing the piano well on your phone indicate that you'd be as skillful with the instrument? At first, I thought that performance would be the same thing as long as you know the keys. Sound quality will vary, but the tune will be similar.
Re: Piano Applications on the Phone [message #95529 is a reply to message #95526] Sat, 16 April 2022 13:13 Go to previous messageGo to next message
My fingers are too fat for the 88 keys on a phone. Laughing
Re: Piano Applications on the Phone [message #97100 is a reply to message #95526] Wed, 25 October 2023 14:11 Go to previous messageGo to next message
Sort of. I've used similar apps for messing around with different drum sets. I assume it's comparable to the experience of playing a piano app versus playing a physical piano. It can give you a feel for following the rhythm and can help you learn the correct finger placements, but it won't provide any tactile feedback, such as how hard to strike the keys and how working the pedals affects the sound.
Re: Piano Applications on the Phone [message #99308 is a reply to message #97100] Wed, 25 March 2026 01:05 Go to previous message
Clint is currently offline  Clint
Strum Drum wrote on Wed, 25 October 2023 14:11
This could also depend on the type of phone that you are using. I can't imagine playing piano on my phone the way that I do with the physical one. It is not always easy!
Previous Topic: New To The Scene
Next Topic: Is the difference in sound quality all in our head?
Current Time: Wed Oct 21 18:44:06 CDT 2026
