Home » Sponsored » Pi Speakers » SPL rating affected by horn?
SPL rating affected by horn? [message #94541] Sat, 02 October 2021 09:51 Go to next message
Hi all,
Do different horns change the combined SPL of a compression driver horn combo?
More specifically, does a narrower horn, say a 60 degree horizontal horn versus a 90 degree horizontal horn change the 1 watt at 1 meter SPL? Same compression driver.
Since the narrower horn is concentrating the output energy, would it have a higher SPL measurement at 1 watt? If so, how much higher on average?
Thanks,
Tom
Re: SPL rating affected by horn? [message #94542 is a reply to message #94541] Sat, 02 October 2021 10:16 Go to previous messageGo to next message
That's exactly right. Horns with narrower patterns deliver higher SPL, and for exactly the reason you describe: Directivity.
And horns that have non-uniform directivity change the response too. That's how horns with collapsing directivity increase on-axis SPL as frequency rises, partially or fully compensating for mass-rolloff. It's also why constant-directivity horns do not compensate for mass rolloff and need "CD equalization."
Re: SPL rating affected by horn? [message #94545 is a reply to message #94541] Sat, 02 October 2021 23:27 Go to previous message
Thanks Wayne!
Previous Topic: 4pi Speakers - Are My Tweeters Wired Incorrectly?
Next Topic: 4pi build with stands finally realized
Current Time: Wed Nov 18 00:49:57 CST 2026
