Home » Audio » Source » marantz 6100 turntable plays slow..Help?
marantz 6100 turntable plays slow..Help? [message #12875] Wed, 26 April 2006 18:02 Go to next message
Shane M. is currently offline  Shane M.
Hi, My Marantz 6100 turntable is playing a little slow. (almost a half step flat in musical terms). I recently replaced the belt when the old one broke but i made sure to research and get the right size and it seems to fit. There is no motor speed control that i can find, inside or out, and the a/c cord basically connects directly to the motor. I have tried oiling the spindle, greasing it, and cleaning it completely with alcohol and still no change. Is there any way to slightly speed up the drive motor? What can i do? Sure appreciate any help. Thanks
Re: marantz 6100 turntable plays slow..Help? [message #12879 is a reply to message #12875] Mon, 01 May 2006 12:06 Go to previous message
Sounds like your motor is probably bad. Might want to run this one in to the shop.
Previous Topic: Turntable "skipping" - Help!
Next Topic: TELEFUNKEN TS-860
Current Time: Thu Nov 05 22:47:54 CST 2026
