Home » Sponsored » Pi Speakers » Pi 4 build and grilles
Pi 4 build and grilles [message #91767] Tue, 28 April 2020 15:20 Go to next message
Phorize is currently offline  Phorize
Hello all.
I'm planning my pi4 build. I'm considering using a front grille, an audio fabric type. Some designers report very modest differences with/without grilles-my understanding is that we are talking fractions of dBs. Are there any reasons for me to not do this with the pi4?
Kris
Re: Pi 4 build and grilles [message #91768 is a reply to message #91767] Tue, 28 April 2020 15:28 Go to previous messageGo to next message
Even the most acoustically transparent grille has some effect on the sound. But it's worth it in a lot of cases for aesthetics, prying hands of small children, animals, etc.
What I like to do is to fashion a grille that can be easily removed, so I can "have my cake and eat it too."
One really cool way to do that is to install neodymium magnets in the grille frame, and matching ones in the cabinet. Cover them with veneer or some other coating so you can't even tell they're there. That way, the speaker can be used with or without the grille.
Re: Pi 4 build and grilles [message #91770 is a reply to message #91768] Tue, 28 April 2020 16:01 Go to previous messageGo to next message
Hi, as a follow on I agree and have seen at craft stores thin plastic picure frames that you cut to fit the opening and could be fastened by the magnets. Just wrap the cloth around the frame and glue it on the inside lip.
Re: Pi 4 build and grilles [message #91772 is a reply to message #91768] Tue, 28 April 2020 16:13 Go to previous messageGo to next message
Wayne Parham wrote on Tue, 28 April 2020 15:28
Thanks Wayne. It's the prying fingers that are my main concern, a removable grille with magnetic fixings is an excellent idea.
Re: Pi 4 build and grilles [message #91792 is a reply to message #91768] Wed, 29 April 2020 13:24 Go to previous messageGo to next message
More questions, thus time about drivers.
I noticed that pi4s used to use JBL 2426 compression drivers. Is there a reason why this was switched to the current options?
Re: Pi 4 build and grilles [message #91793 is a reply to message #91792] Wed, 29 April 2020 16:59 Go to previous message
The JBL 2426H was our upgrade option for many years. It's a great driver, and the plans still list it and show the crossover parts needed to run it.
We later changed to the B&C DE250 because it also is an excellent driver, and it costs about a third of what the JBL driver costs. It actually measures a little better too.
Still, if you want an all-American version of our four π model, use a JBL 2426H compression driver and a JBL 2226H midwoofer. That makes an excellent speaker.
Similarly, the TAD TD-2002 is a compression driver I've considered listing as an upgrade option from time to time. It extends the top-end a half-octave, due to its beryllium diaphragm. It is very expensive, but for a price-no-object version of our speakers, mount one of those on our waveguide. It can't be beat.
But the DE250 is the upgrade driver we offer because it is just sounds so nice. It is detailed but still smooth, and it measures well. Its cost makes it a no-brainer, in my opinion.
Previous Topic: Cabinet best practices
Next Topic: 4Pi plan request and question.
Current Time: Sat Nov 28 14:04:58 CST 2026
