Home » Sponsored » Pi Speakers » 3pi crossover
3pi crossover [message #88426] Wed, 11 July 2018 23:13 Go to next message
dbbarnes2 is currently offline  dbbarnes2
on the 3pi crossover schematic where it has a L3 and jumper, What is mh required for that coil?
Re: 3pi crossover [message #88427 is a reply to message #88426] Thu, 12 July 2018 08:55 Go to previous messageGo to next message
There is no L3 coil in the three π loudspeaker. A wire jumper is used in place of a coil in position L3.
Re: 3pi crossover [message #88428 is a reply to message #88427] Thu, 12 July 2018 14:05 Go to previous messageGo to next message
Thanks for the reply Wayne, I was wondering why that was the only one with out specs next to the l3. I'm trying to research now how jumper wires work on the crossover and how it is set up. Do you have any recommended links to articles or videos for that?
Re: 3pi crossover [message #88429 is a reply to message #88428] Thu, 12 July 2018 16:12 Go to previous messageGo to next message
Each model uses a different crossover. The midwoofer circuits are usually pretty similar and the tweeter circuits are almost always nearly the same, except for the R1/R2 values. But different drivers use slightly different parts.
You can learn more about the design/optimization process at the link below:
Re: 3pi crossover [message #88430 is a reply to message #88429] Thu, 12 July 2018 22:49 Go to previous message
Loads of info!!! Thank you so much
Previous Topic: 4Pi Rough concept
Next Topic: Build Thread: 2Pi Towers, 6Pi Corner horns (and possibly a sub and center)
Current Time: Sat Nov 28 14:08:08 CST 2026
