Home » Audio » Craftsmen » How to make Bass Traps
How to make Bass Traps [message #87879] Thu, 26 April 2018 06:10 Go to next message
SamW is currently offline  SamW
A friend has a great listening room and we want to make a few bass traps for it. We've got the frames made and have cut birch playwood for the panels. W've ordered Knauf two-inch, 3lb insulation from GIK.
We hope to be able to get them mounted over the weekend - but we're not sure how big an air gap to have between the traps and the wall.
Any advice?
Sam
Re: How to make Bass Traps [message #87883 is a reply to message #87879] Fri, 27 April 2018 13:32 Go to previous message
In my experience corners are considered to be the best place for bass traps, or at least the best place to start in a standard residential room.
But they need to be very thick to absorb bass.
The cheapest and most typical diy bass trap is just a 2'x4' piece of compressed fiberglass (ex. Owens 703) set up vertically in a corner, with some batt insulation loosely shoved behind it.
You could also stack them, creating an 8 foot tall trap
It could be covered with a thin, acoustically transparent material like cheap spandex (stocking material).
The traps that I have built over the years, never use any type of frame or backing material.
The bass wave travels directly through the material, bounces off the back wall and then has to travel back through the trap and into the room again.
This is different than a resonant panel absorber
Previous Topic: DIY/Hacks That Failed
Next Topic: Safety Gear
Current Time: Wed Nov 04 22:56:44 CST 2026
