Home » Audio » Source » Mass and tonearm geometry/Empire
Mass and tonearm geometry/Empire [message #12213] Sun, 05 June 2005 11:20 Go to next message
Say Wayne; I remmembered your post concerning the mass of the tonearm and any effects it has on tracking the groove. The compliance of the stylus is only part of the story; no? Does the spring action of the stylus decouple the arm from the stylus/arm/groove system?
Lateral force is exerted by the groove rotating against the stylus that must move this mass of the arm; is that correct?
Re: Mass and tonearm geometry/Empire [message #12216 is a reply to message #12213] Sun, 05 June 2005 22:01 Go to previous messageGo to next message
If you mean the movement required to bring the arm inward towards the center of the record, yes, tone arm mass comes into play there. But it is a very slow movement, and acceleration is almost zero because the speed is constant. I would expect the force to overcome friction would be greater, and with good bearings, it is pretty small too.
Re: Mass and tonearm geometry/Empire [message #12217 is a reply to message #12216] Mon, 06 June 2005 06:44 Go to previous messageGo to next message
Yeah; thats a point but also during the tracing of the groove the stylus compliance is exceeded periodically due to groove modulation and as a result the arm must respond to that exception. If it is too massive for the stylus; would that not have a negative effect causing groove damage?
Whats your take on that?
Re: Mass and tonearm geometry/Empire [message #12221 is a reply to message #12217] Mon, 06 June 2005 14:31 Go to previous messageGo to next message
I can see what you mean; When a record is warped or off-center, then the tone arm moves to track the groove. So that would create more force on the groove and also make a very low frequency audio component. We've all seen the low frequency part - woofer flutter. It might also cause increased record wear from some tone arms.
Re: Mass and tonearm geometry/Empire [message #12222 is a reply to message #12221] Mon, 06 June 2005 15:19 Go to previous message
Agreed; considering the lateral tracking error built into all tonearm geometry the potential for damage may be pretty serious.
Still mulling this over but as of now I would suggest following the lowcompliance massive arm rule.
Previous Topic: BSR 710: repair or replace?
Next Topic: y´all gotta check this guy out!!!
Current Time: Thu Nov 05 23:37:53 CST 2026
