Home » Audio » Home Theater » Speaker Static
Speaker Static [message #85916] Wed, 23 August 2017 08:40 Go to next message
Kirkman is currently offline  Kirkman
I've been having trouble with speaker static off and on for the last few weeks. I checked all the connections and at first it helped, but the static is back. Any other suggestions for how to fix it?
Re: Speaker Static [message #86017 is a reply to message #85916] Fri, 01 September 2017 19:23 Go to previous message
Lost the Remote is currently offline  Lost the Remote
There could be too much power moving through them, but if so, I believe it would have happened when you first turned them on and it wouldn't go away. Can you change the cords out? There could be a short, or they might not be properly shielded, but since messing with the cords made a difference before, I'd say that's what needs replaced.
Previous Topic: Power surges
Next Topic: Packing your system
Current Time: Tue Sep 22 04:24:07 CDT 2026
