Home » Audio » Source » Turntable refuses to rotate
Turntable refuses to rotate [message #12173] Wed, 25 May 2005 07:15 Go to next message
line is currently offline  line
Hello,
I found this forum in a web search, and I hope someone here can help.
I have an auto-return turntable phonograph (Sanyo TP B2) that looks something similar to the ones in this picture:
http://en.wikipedia.org/wiki/Image:TurntablesWWOZ.jpg
Today I rotated the turntable clockwise manually while I was cleaning its surface with a towel. Apparently I messed up something, because since then, the turntable doesn't work. I put a platter on, mount the arm (which turns on the phonograph), but the turntable doesn't rotate. It's not stuck, though, I can still turn it manually.
Is this a common problem? What can I do about it?
Thanks!
Re: Turntable refuses to rotate [message #12174 is a reply to message #12173] Wed, 25 May 2005 09:04 Go to previous messageGo to next message
The turntable you mentioned has a belt drive. If you rotate the platter by hand, you may have dropped, stretched or broken the belt. Remove the record mat and look and see if the belt is off.
Re: Turntable refuses to rotate [message #12177 is a reply to message #12174] Wed, 25 May 2005 12:42 Go to previous message
Yes, that was it. Many thanks, Wayne.
Previous Topic: Maxed Linn
Next Topic: Empire 298
Current Time: Thu Nov 05 23:38:42 CST 2026
