Home » Audio » Measurement » Sound distortion
Sound distortion [message #85334] Sun, 04 June 2017 02:25 Go to next message
cwemoy is currently offline  cwemoy
I'm aware that input noise isn't factored when talking about measurement. Having said this, how is sound distortion measured and what does 1% sound distortion mean? I'm saying this with the understanding that we still have different types of distortion.
Re: Sound distortion [message #85343 is a reply to message #85334] Sun, 04 June 2017 13:18 Go to previous messageGo to next message
Actually, noise is usually factored in when making distortion measurements. One should know the noise floor, and realize that beneath it, harmonics and other distortions are "invisible" to the measurement gear. They are said to be lost "below the noise floor." The term THD+N is total harmonic distortion plus noise.
Re: Sound distortion [message #85348 is a reply to message #85343] Sun, 04 June 2017 14:13 Go to previous messageGo to next message
I agree, my HP distortion analyzer considers noise as distortion.
Re: Sound distortion [message #85354 is a reply to message #85334] Mon, 05 June 2017 06:38 Go to previous messageGo to next message
This gets me confused at times. Much as THD comprises of all harmonic distortion products in a measurement, how does it differ from selective harmonic distortion?
Re: Sound distortion [message #85359 is a reply to message #85354] Mon, 05 June 2017 10:36 Go to previous message
Some harmonics are more discordant than others. Odd harmonics sound worse than even harmonics do, and higher harmonics sound more edgy than lower ones. So if you have 5% second harmonic in one environment and 3% fifth harmonic in another, the latter will sound worse even though the percentage of distortion in the first case is higher.
Previous Topic: Audio measurement on mobile phones
Next Topic: What is a parallax error?
Current Time: Sun Oct 18 19:27:48 CDT 2026
