Home » Audio » General » Isolation
Isolation [message #85246] Thu, 25 May 2017 04:26 Go to next message
How do you best deal with this? Vibrations occuring in a room can be quite distracting and distorting to the sound. How are surfaces that vibrate best isolated from each other?
Re: Isolation [message #85248 is a reply to message #85246] Thu, 25 May 2017 12:35 Go to previous messageGo to next message
Constrained layer damping is the best way I can think of. It decouples two rigid surfaces with a viscous material between them to provide damping.
Re: Isolation [message #85255 is a reply to message #85246] Fri, 26 May 2017 01:53 Go to previous message
vhfspeeks is currently offline  vhfspeeks
Decoupling surfaces is the best way to stop it. If this is flooring with something standing on it, something as simple as putting a rug down can help, or hanging fabric drapes in front of windows.
Previous Topic: Will they get cheaper with time?
Next Topic: Headphones that spy on you?
Current Time: Sun Nov 08 04:52:09 CST 2026
