Is it true that if you are looking for earphones/headphones with these features, the cost will most likely go up? I have read reviews before and most people think that this is just another marketing gimmick. Is there such a thing as this?
gofar99 Messages: 2059 Registered: May 2010 Location: Southern Arizona
Hi, My personal experience is that while it works, I don't like it. I bought 3 different NC headphones for use on airplanes. All cut the noise and all colored the sound excessively IMO. I found the best solution was either snug fitting in ear phones of good quality and good fitting fully enclosed over the ear phones. Both maintained the sound quality and also cut the noise level. Now on the plus side if you don't bother with the sound (no audio) the noise cancelling phones did make the trip quieter.
Apart from issues to do with cost, I notice that there's high power usage with the internal components. Again, they don't seem to cancel or block all the noise. Overall, they aren't such a bad idea after all.
