Home » Sponsored » Pi Speakers » 18" corner horn design
18" corner horn design [message #84503] Tue, 07 February 2017 00:46 Go to next message
misentoro is currently offline  misentoro
I read on your site:
"The five pi through seven pi are corner horn designs with 10", 12", and 15" woofers respectively."
Could a design with 18" woofers work?
Has it been tried?
What compromises would be made?
My goal is a system with a little more SPL using the corner horn design.
Re: 18" corner horn design [message #84507 is a reply to message #84503] Tue, 07 February 2017 10:01 Go to previous messageGo to next message
Sure, we've built them with 18" woofers. They're pretty much just like the 15" models, but larger. One I liked a lot used the JBL 2242 or 2245 woofer.
Re: 18" corner horn design [message #84525 is a reply to message #84507] Wed, 08 February 2017 21:34 Go to previous messageGo to next message
This is great. Could I please get the plans for pi7 and a little direction on how I might calculate making the enclosure larger?
Re: 18" corner horn design [message #84531 is a reply to message #84525] Thu, 09 February 2017 09:47 Go to previous message
You've got mail!
I've sent the standard plans and added an attachment that shows the dimensions for the bass bin for the JBL 2242 or 2245 woofers. Some other high-efficiency 18" woofers will work in this cabinet too - It's 7.5ft3 tuned to 30Hz.
Use the crossover, midhorn and tweeter as shown in the plans. Don't substitute drivers in those because they're more critical to the design. Options for midhorn and tweeter are shown in the plans.
Previous Topic: 3 Pi speaker driver selections
Next Topic: 3 pi plans and a woofer question
Current Time: Mon Oct 26 09:00:48 CDT 2026
