gofar99 Messages: 2060 Registered: May 2010 Location: Southern Arizona
You don't need a special plug for PC audio...any spare line level one (aux, tape, cd etc) will do. If you want to directly use something like a USB connection then an adapter will be needed that converts USB to audio. Same goes for optical and similar PC outputs. Most AV gear now has HDMI inputs and now many PCs do as well. That IMO is the best way to connect. Older gear often does not have HDMI capability.
