Home » Audio » Source » BSR help
BSR help [message #11910] Tue, 08 February 2005 11:29 Go to next message
Andy is currently offline  Andy
I bought an old BSR from a garage sale a while ago. It's my first one, so I'm still learning things about turntables in general. Everything works quite well (I got a new needle), and it plays great, but every now and again the audio nearly completely shuts out. Seemingly for no reason, the audio will almost completely cut and there will be a slight static at a very low volume. If I gently tap on the arm, it seems to realign (?) itself and the audio comes back easily. Also, and this is the part that confuses me, if I'm in the other room and the audio cuts out, if I turn off the kitchen light the audio will come back on. No effect when I turn the light on, but only when I turn it off. (I live in a fairly cheap apartment). Could this be the levelness of the turntable, or the weight of the needle on the record, or something else? Thank you all very much in advance for your help.
-Andy
Re: BSR help [message #11912 is a reply to message #11910] Tue, 08 February 2005 12:29 Go to previous messageGo to next message
You have an electrical problem; try another outlet on a different circuit breaker.
Re: BSR help [message #11922 is a reply to message #11912] Wed, 09 February 2005 21:57 Go to previous message
Yep. That was it. Thank you very much.
Previous Topic: soliciting turntable purchase and record care advice
Next Topic: Sansui Turntable - Cartridge?
Current Time: Sun Sep 27 00:56:23 CDT 2026
