Home » Audio » General » Laptop charger problem
Laptop charger problem [message #83448] Thu, 01 September 2016 05:58 Go to next message
I have had this laptop for 3 years now but it seems it is starting to have a problem with either the charging unit or battery.
With the charger plugged in, nothing seems to be going on. The charging icon is indicated on the battery but no charging is taking place. What could be the problem?
Re: Laptop charger problem [message #83450 is a reply to message #83448] Thu, 01 September 2016 06:37 Go to previous messageGo to next message
Thaddeus is currently offline  Thaddeus
Most likely it is your battery. I have an older laptop and I have to replace the battery in it every 4 years. I would start with that first and if you are still having problems then replace the charger.
Re: Laptop charger problem [message #83462 is a reply to message #83448] Fri, 02 September 2016 15:43 Go to previous message
I am a bit taken aback because replacing a laptop battery was never in my imagination. It has been two years ever since I bought my laptop. Does the warranty cover such issues?
Previous Topic: Audio and MIDI difference
Next Topic: Ham radio license cost
Current Time: Tue Nov 17 23:23:37 CST 2026
