Is anyone else having issues with Firefox these days, or is it just my system? Slow to load....doesn't want to work 2 tabs at once....and the strangest thing is this: The Homepage won't load, it says there is no internet connection to that, but the bookmarked tabs will as well as sites typed into the search bar. ?? ??
gofar99 Messages: 2060 Registered: May 2010 Location: Southern Arizona
Hi, mine works fine. On a given screen type contl + to make everything bigger and ctrl- to make it smaller. Each command can be used more than once to get as big or small as you want. Usually going to a new tab will be back to the normal size. Some however will stay the way you put them.
