Home » Audio » Craftsmen » Seeking advice on de-soldering
Seeking advice on de-soldering [message #82242] Fri, 18 March 2016 13:17 Go to next message
Thaddeus is currently offline  Thaddeus
Can anyone give me any tips or advice on how to de-solder components from a circuit board? I need to replace a relay but I haven't had very much luck in the past de-soldering things. Any suggestions?
Re: Seeking advice on de-soldering [message #82244 is a reply to message #82242] Fri, 18 March 2016 14:11 Go to previous messageGo to next message
Use a desoldering wick. Desoldering is harder than soldering, so just work at it. Sometimes you can get enough to work out the device and once free, you can do a final cleaning of the PCB lands.
Re: Seeking advice on de-soldering [message #82253 is a reply to message #82244] Sat, 19 March 2016 13:24 Go to previous messageGo to next message
Hi, If you need to do this often (like me) then check out something like the BK4000 desoldering tool from Circuit Specialists. They are often discounted to about $50. Replacement tips, guns etc are also available. Mine works like a champ. A cheaper solution is the bulb type desoldering tools. Often in the $10-15 range. They do require some skill to use though.
Re: Seeking advice on de-soldering [message #82294 is a reply to message #82242] Tue, 22 March 2016 12:36 Go to previous message
Nouri is currently offline  Nouri
That's some good information. I always did wonder how the relays and such could be taken out. I knew they were soldered, but I don't know much else.
Previous Topic: Taking a class to learn these skills
Next Topic: Soldering with Shaky Hands
Current Time: Thu Oct 15 20:39:55 CDT 2026
