Home » Audio » General » Headphones With No Sound
Headphones With No Sound [message #81955] Fri, 05 February 2016 09:00 Go to next message
Airforce 3 is currently offline  Airforce 3
Why am I getting no sound on my headphones? They're plugged in to a front jack and I can see the sound metre moving, but no sound. Any ideas? I've tried everything.......I think.
Re: Headphones With No Sound [message #81962 is a reply to message #81955] Fri, 05 February 2016 14:36 Go to previous messageGo to next message
Are you sure the headphones work?
Have you used them in something else recently?
Re: Headphones With No Sound [message #81968 is a reply to message #81962] Sat, 06 February 2016 11:37 Go to previous messageGo to next message
Hi, Are you sure there is a headphone level signal at the jack? It might be an input jack for a mic. There might also depending on what you are using a setting or switch to enable the headphone jack.
Re: Headphones With No Sound [message #82029 is a reply to message #81962] Mon, 15 February 2016 11:53 Go to previous message
A friend gave them to me because he upgraded. They worked just fine on his system. I'm still fiddling with it, so I'll look into the compatibility angle.
Previous Topic: Replacing a car stereo -- DIY or go pro?
Next Topic: Crackling audio problem
Current Time: Thu Nov 12 06:34:43 CST 2026
