mlevans Messages: 1 Registered: November 2015 Location: Virginia, USA
Trying to figure out how to configure my audio system to play company jingle every 3 minutes or so then return to music. I use standard Bogen 70V system with several inputs and mute capability.
Every 360 seconds or so I want to mute the music and play the jingle.
Jingle is in continuous loop but how do I mute the audio just at the start the jingle? How do I coordinate things so the jingle plays from the beginning each time?
Bogen has several systems available, and the instructions for doing what you need to do are specific to the system. So contact Bogen for support. They should be able to help you.
Can't you just put the jingle on a timer? Leaving 3 seconds or so between the end of music and the start of the jingle? This is standard technology that I'm sure Bogen can accommodate.
