Home » Sponsored » Pi Speakers » Midhorn Dispersion
Midhorn Dispersion [message #81586] Mon, 21 September 2015 23:01 Go to next message
B1189BW is currently offline  B1189BW
A follow up question from the Pro Audio Forum about the midhorn dispersion. What is the dispersion of your midhorn because I can not find it in the literature?
Second question: I will be coming out of the midhorn loaded with JBL 2012s at 1200 HZ into JBL 2450s. I have my choice of JBL horns 2382A (120 X 40) or 2380As (90 X 40).
Which JBL horn would match up best with your midhorn?
Thank you,
Bill
Re: Midhorn Dispersion [message #81590 is a reply to message #81586] Wed, 23 September 2015 08:45 Go to previous message
The midhorn provides 90° x 40° coverage when used as intended, sitting in a corner.
Previous Topic: 60 x 40 midbass horn...
Next Topic: Midhorns are back!
Current Time: Sat Oct 24 14:17:05 CDT 2026
