Home » Audio » Radio » Radio isn't working
Radio isn't working [message #81153] Wed, 18 February 2015 21:40 Go to next message
Equinom is currently offline  Equinom
Not sure what the issue is! I was in my mother's car the other day, and I went to turn on the radio during our drive. She stopped me and said it no longer worked, I tried it...and sure enough, it was dead. It didn't do anything. Is it cheaper to buy a new one for the vehicle than fix the current one?
Re: Radio isn't working [message #81160 is a reply to message #81153] Fri, 20 February 2015 04:43 Go to previous messageGo to next message
Round2 is currently offline  Round2
How old is your mother's car? It's odd that it's not working, I have a car that is 12 years old and the radio works better than the car! You could probably get one under $100. If you put it in yourself it would be cheaper than paying for labor at the garage.
Re: Radio isn't working [message #81165 is a reply to message #81160] Fri, 20 February 2015 21:36 Go to previous message
Hi....sounds dumb, but check for the fuse in the fuse box. There also could be one in line. Another easy thing is to check that the connectors on the rear of the radio are connected. Once in a while one will work loose. If all else fails new ones are likely better and are not too expensive. Many shops will install them for free or nearly nothing.
Previous Topic: Radio Sports Talk
Next Topic: Local radio station signal
Current Time: Sun Oct 18 19:37:35 CDT 2026
