| Speaker placement and wavefront launch, revisited [message #81025] |
Thu, 22 January 2015 09:45  |
George Swanson
Messages: 4 Registered: January 2015
Esquire |
Hi Wayne,
I'm finally able to access the forum! I sent you an email about Four Pi loudpeakers but I've been having issues with my personal email, sooo...
I'd like a copy of the plans but I also asked about designing a corner bass reflex (or Jensen style corner Onken) cabinet for the JBL driver so I can try corner loaded constant directivity horns without going the whole hog and building the Seven Pi corner horns. Would one need to redesign the crossover in order to do that?
Also, I'm interested in purchasing a set of waveguides. Do you also sell the B&C compression drivers and woofers?
Thanks,
George
| Re: Speaker placement and wavefront launch, revisited [message #81027 is a reply to message #81025] |
Thu, 22 January 2015 10:53   |
I got your email and replied. But if you didn't see it, I'll post the jist of my reply here.
The best way to do what you're saying is to build the seven π cornerhorns, as shown in the plans. They are designed to be true constant directivity cornerhorns, and they have specific features that make them better suited for corner placement. For one thing, the sound sources are acoustically close to the apex of the corner, so there is no self-interference. And for another thing, the crossover is optimized for the application.
The problem with putting a DI-matched two-way speaker in a corner is that the midwoofer is only acoustically close at low frequencies. At higher frequencies, from midrange up, the midwoofer is acoustically distant but is not directional enough to reduce reflections. So the nearest boundaries give self-interference from reflections.
Flanking subs help mitigate this problem, but they're really designed to deal with the self-interference notches that occur at the upper end of the modal region, just below the Schroeder frequency. Above that, the sound field is statistical and reflections are "blended" with direct sound, but still, early reflections are never desirable.
And that's what we have with a speaker mounted close to the wall but not flush with it, e.g. acoustically distant. Seems like the worse case is between 1/4λ to 1/2λ and around 2λ or 3λ. Any further and the statistical blending works well. And of course, closer than 1/4λ is acoustically close, basically the same as in-wall mounted, having no reflection. It's the in-between range that muddies the sound.
