Home » Audio » Speaker » Always Replacing Earbuds
Always Replacing Earbuds [message #80350] Sun, 31 August 2014 07:45 Go to next message
I guess I'm hard on my earbuds. Ever since I started working out more regularly, I go through them more often. Usually the wire gets exposed where it attaches to the stereo plug and then I start losing signal in one or both sides. Maybe I need to find more durable ones instead of making do with the junk from Walmart.
Re: Always Replacing Earbuds [message #80381 is a reply to message #80350] Wed, 03 September 2014 19:53 Go to previous messageGo to next message
iLoveiPod is currently offline  iLoveiPod
I don't know if I'd start buying more expensive ear buds just yet. I have bought the cheap ones as well as the more expensive ones and it seems like the "life time" is about the same either way.
Re: Always Replacing Earbuds [message #80418 is a reply to message #80350] Sun, 07 September 2014 08:23 Go to previous messageGo to next message
Oh well that's not great news. Don't they make any specifically for athletes that might last longer? It would probably help if I were not so clumsy. I frequently accidentally catch the cord on the machines.
Re: Always Replacing Earbuds [message #99358 is a reply to message #80350] Sat, 18 April 2026 00:25 Go to previous message
George is currently offline  George
Wireless earbuds are the best alternative that you've got to consider. Some brands like Apple Brands are good and have features like the noise cancellation system that makes you work out seamlessly and enjoyable. You can consider getting one from them, and you will be glad you did.
Previous Topic: Latest waterproof speakers suited for a pool party
Next Topic: What has been your experience on Bose SoundLink Max?
Current Time: Mon Nov 09 10:23:38 CST 2026
