| Kit vs. Finished Speakers [message #79882] |
Mon, 28 April 2014 20:24  |
Satyaa
Messages: 1 Registered: April 2014
Esquire |
Hi all, I am new member on the forum and am researching speakers for HT setup for a 13' x 23' living room with cathedral ceiling.
I was hoping to buy a set of finished speakers for under $2K but it doesn't seem possible.
I am wondering whether I should buy the kits and build the speakers myself. I searched for 'kit vs finished' speakers on the forum and found nothing.
I have two questions...
1. How easy/difficult is it for a newbie to assemble speakers from these kits? I am new to cabinetry and was going to get into it for other things anyway. I can handle wiring connections/soldering/etc., but don't know anything about electronics.
2. The cost difference between kits and finished speakers is significant. Leaving the time and effort aside, how much would the material typically cost for decent cabinets (3 x Three Pi and 2 x Two Pi)?
If I go that route, I would have to spend a couple of months to get the cabinets ready and then order the kits when I am ready! That way, I won't have the kits sitting in the basement while I am learning to build cabinets.
Any advice from your experience is appreciated.
Thanks,
Satyaa
Researching for a new HT setup
| Re: Kit vs. Finished Speakers [message #99808 is a reply to message #79882] |
Fri, 18 September 2026 01:21  |
Hank
Messages: 72 Registered: December 2025
Viscount |
Hey, welcome here.
The thing is that I built my first Pi kits years ago as a total newbie and found them easier once I slowed down. The plans are comprehensive, and if you can solder like you said you’ll handle the wiring fine. I didn’t know electronics either and still pulled through.
I spent about $180 on MDF for three 3π and two 2π cabinets from the local lumber yard. Plywood would have run higher. Flat-packs are an option if cutting panels feels intimidating at first.
I like your idea of finishing the boxes before ordering the kits. That’s exactly what I did, so nothing sat unused in the basement while I practised.
Take your time, measure thrice, and feel free to ask me anything here if you are stuck with it.
