Home » Audio » Home Theater » Room Size
Room Size [message #79493] Wed, 19 February 2014 05:29 Go to next message
Samuel is currently offline  Samuel
I'm sure that there are optimal sizes for the rooms that you plan to set up your home theater in. But what about a bare minimum room size? If you were limited for reasons beyond your control, what is the minimum amount of space that you need?
Re: Room Size [message #79522 is a reply to message #79493] Fri, 21 February 2014 01:25 Go to previous message
timron is currently offline  timron
Samuel wrote on Wed, 19 February 2014 05:29
I think you can do something in any size room, even one as small as a bathroom. I just think you have to tailor the home theater equipment that you pick out to be suitable for the room you're planning to use. I wouldn't put a 7.1 Dolby Digital surround sound system in that bathroom, for example, but a sound bar certainly isn't out of the question.
Previous Topic: Minimize or Show it Off
Next Topic: Calibrating speakers
Current Time: Fri Nov 20 08:43:27 CST 2026
