Home » Audio » General » Sound fading in and out
Sound fading in and out [message #79487] Wed, 19 February 2014 02:07 Go to next message
timron is currently offline  timron
I have a home theater system that is way too new to be giving me problems. It doesn't seem to know that (or care), however, and the sound is fading in and out. I've checked all the speaker wires and don't see anything loose. What else could it be?
Re: Sound fading in and out [message #79492 is a reply to message #79487] Wed, 19 February 2014 05:23 Go to previous messageGo to next message
Samuel is currently offline  Samuel
Can you describe it a little more please? Is the sound actually getting louder and quieter over the speakers when you are sat in one place, or is it as you move across the room (as in you have quiet spots). Does it do it if you use a headset?
Re: Sound fading in and out [message #79505 is a reply to message #79492] Wed, 19 February 2014 20:24 Go to previous messageGo to next message
Hi, Is the sound still clean and undistorted? Often if a device has this sort of problem it is related to power to the amplifier sections. Are there any other symptoms?
Re: Sound fading in and out [message #79508 is a reply to message #79492] Thu, 20 February 2014 02:20 Go to previous messageGo to next message
Samuel wrote on Wed, 19 February 2014 05:23
Yes, the sound actually gets louder or quieter when we are sitting on the couch. It's not a matter of our movement. I don't know if it happens with headphones, though, because I never use them with this system.
Re: Sound fading in and out [message #79509 is a reply to message #79505] Thu, 20 February 2014 02:21 Go to previous messageGo to next message
gofar99 wrote on Wed, 19 February 2014 20:24
Yes, the sound is still clean and undistorted and no, there are no other symptoms that I can discern. I really thought it would be loose speaker wires but when everything checkout out, I was absolutely stumped.
Re: Sound fading in and out [message #79883 is a reply to message #79509] Mon, 28 April 2014 20:32 Go to previous message
I've seen it in the decoder sections of some receivers, if the source was recorded in DTS, Dolby Prologic etc, sometimes the receiver will have a hard time deciphering the difference. Make sure your speaker selection is set up right, Left and Right channels, Center channel if your using one, and the left and right rear channels. Some receivers you can set the distance between the front and rear speakers and control the volume levels between each of the speakers to your listening position.
Previous Topic: Cable Differences
Next Topic: "Are Audiophiles Wasting Their Money?"
Current Time: Thu Nov 12 06:34:50 CST 2026
