Home » Audio » Thermionic Emissions » Ping: Speakerman57
Ping: Speakerman57 [message #11241] Thu, 27 October 2005 17:52 Go to next message
Hi Ron,
Have you had the opportunity to hear the Yamamoto DC 300B and 45 SET amplifiers? If so, could you give us a comparison between your 45 SET and the DC heated models by Yamamoto?
And finally, what would you consider to be a good horn three or four way system that has the mid-bass through treble drivers horn loaded and uses a quality bass reflex or better sub-bass design? Price no object to a realisticly priced system that can be bought on the used market for the cheapskates and poor audiophiles.
I am looking forward to your reply.
Thanks
Norris Wilson
speaker part [message #11242 is a reply to message #11241] Thu, 27 October 2005 19:04 Go to previous messageGo to next message
The speaker question is about as complex as it comes. I have a 3-way, and it is going to get a bit of an update soon.
Bass: JBL 4560 cabs loaded with EVM-15L EV's
Mids: Fostex FE107, horn loaded with 18" axial length, 30-degree included and a 2" throat.
Top: an old R-S horn. Not all that efficient, but it works, and has for a long time.
Updating the mids to an AlNiCo RCA compression driver, and I'll re-make the horn so as to compliment the old RCA.
Itching to try a ribbon for the top. One of the more affordable will be adequate.
This can be assembled quite inexpensively. Nobody has said it sucks yet...
cheers,
Douglas
Re: speaker part [message #11245 is a reply to message #11242] Fri, 28 October 2005 20:39 Go to previous messageGo to next message
PeterP is currently offline  PeterP
Douglas,
"Mids: Fostex FE107, horn loaded with 18" axial length, 30-degree included and a 2" throat."
I just finished a little 6L dual port FE107E. Right now I'm using it full range as an office system. I was wondering as to what crossover points are you using your horn? I really like the mid-range of this speaker.
When used in your system as a horn loaded mid, is it capable of "party" levels? There is just too much break-up when playing high volume levels at full range for me to tell if it's worth putting this driver into my main system.
Is the:
"Bass: JBL 4560 cabs loaded with EVM-15L EV's " the same ones that you had in MD?
Regards,
Pete.
Re: speaker part [message #11246 is a reply to message #11245] Fri, 28 October 2005 20:53 Go to previous messageGo to next message
Hey-hey!!!,
The system only has ~12 W behind it. It has no problems with high volume. I bounced the cone off the throat plate when I crossed it at ~400cps with a 1st order series cap. The horn unloaded, and excursion went up.
Right now it has a 20 uF series cap as its x-over. An old PCB GE AC cap. This puts it at ~1000 cps or so. Single L in series with the 15".
The 4560 is like the Altec A-7 bass bin with a slightly smaller volume. The 12" BR boxes I brought to MD are still in action from time to time, and are distinctly diffferent from the bigger JBL's.
cheers,
Douglas
Yamamoto 45 amp and Wellborne DRD 300B [message #11247 is a reply to message #11241] Mon, 31 October 2005 09:00 Go to previous message
spkrman57
Norris,
Good to hear from you! I have the amps listed above and they are a close match to each other with the Yamamoto being slightly better(and only slightly less powerful sounding).
I will try and be more descriptive in a future post as free time has been limited lately with domestic/family issues.
I am using the EML 45's with the Yamamoto and they sound great!
Ron
Previous Topic: Anyone tried other op points in Guinevere?
Next Topic: Need power supply schematic for Merlin amplifier?
Current Time: Sat Oct 17 00:47:31 CDT 2026
