audioaudio90 Messages: 623 Registered: October 2010
I found an old DAT and some zip discs with audio projects on them. I know someone with a zip drive so transferring those won't be an issue, but I don't have a DAT machine. I guess it would probably be easiest to reach out to a local production studio and see if anyone can convert it for me, huh?
Round2 Messages: 108 Registered: September 2013 Location: Canada
Have you tried searching online to see if you can rent one in your area? There are some places when you search on Google that rent them out and it may be cheaper than having someone else do it.
gofar99 Messages: 2060 Registered: May 2010 Location: Southern Arizona
It would take two steps but you could feed them into a PC and then make CDs from the PC files. There is lots of free software that will do the job. It does assume you have a good sound card or other interface device that will not degrade the bit and sample rate of the originals.
gofar99 wrote on Thu, 24 October 2013 18:16
My sound card isn't that great, and in any case, I don't have the hardware to play the DAT. I haven't even seen a DAT machine in years.
