Home » Sponsored » Pi Speakers » Midrange horn shape in Pi cornerhorn
Midrange horn shape in Pi cornerhorn [message #74979] Mon, 17 December 2012 08:43 Go to next message
yscai is currently offline  yscai
The midrange horn constructions are all straight lines with no curves. I understand it is an easy to build plan, but would that affect the sound quality? Does the horn kit has some curvature or the same straight line construction?
Re: Midrange horn shape in Pi cornerhorn [message #74980 is a reply to message #74979] Mon, 17 December 2012 09:09 Go to previous messageGo to next message
The midhorn flare profile is conical, which is straight-sided and is the best shape for a spherical wave. Since the midrange driver and its cone shape/features are acoustically small at the wavelengths it is used at, it acts as a point source so its radiation pattern is spherical. If it were used in free space, its radiation would be omnidirectional, but the midhorn constrains the radiation angle to a spherical section that matches the wall angle.
The midhorn is also acoustically close to the room corner at the low end of its passband, which acts something like an extension to the flare at the lowest frequencies. And of course, the corner is the waveguide for the midbass too, providing directivity control from the Schroeder frequency upwards.
This is a little different than a compression driver, which generates a plane wave. Since the output of a compression driver is a plane wave, it needs a curved transition region to bend the plane wave into a spherical wave section. The oblate spheroidal flare profile provides this interface.
The reason a compression driver generates a plane wave is because it has a phase plug. The phase plug has a large number of small slots that direct the sound through it and maintain consistent path-length distance to provide a planar wavefront. So to work with this plane wave, the tweeter horn flare profile is oblate spheroidal. But for a spherical wave, you want conical, which is what the midhorn is.
There is a comparison of the cross-section profiles of conical and oblate spheroidal flares in the following post:
Drilling down further, down into the jot and tittle level, you'll find that neither the compression driver can produce a perfect plane wave nor the direct radiator (of any shape) can produce a perfect spherical wave. But they're close.
The driver with a phase plug produces a wavefront that most closely approximates a planar wave. Of course, this is largely determined by the number and position of slots in the phase plug, because it takes equal path lengths to produce a flat isophase wavefront across the exit aperture throughout the passband. For example, circumferential slots tend to have a single pronounced resonant mode that creates a notch at some frequency whereas radial slots tend to act more like a gradual drift away from their ability to maintain phase. There are combined approaches as well, having characteristics of each phase plug type. But in general, a compression driver with a phase plug produces a plane wave at its exit.
Likewise, the direct radiator produces a wavefront that most closely approximates a spherical wave, no matter what shape the diaphragm is, as long as it (or the aperature it is playing through) is acoustically small. That's why there are so many diaphragm shapes, from flat surfaces to straight cones to curvillinear cones to domes, inverted domes and even complex shapes that don't resemble any simple geometric shape. All produce spherical waves provided they are acoustically small. Even though the shapes are different, having different path lengths across their surface, as long as the the path length difference is less than a half-wavelength, it tends to act like a point source making a spherical wavefront.
Re: Midrange horn shape in Pi cornerhorn [message #74981 is a reply to message #74980] Mon, 17 December 2012 10:28 Go to previous message
Aha, that makes sense. Thanks for the detailed explanation.
Previous Topic: 7 Pi at bay window corner
Next Topic: 4 Pi plans
Current Time: Sat Oct 24 17:02:48 CDT 2026
