Home » Sponsored » Pi Speakers » 7 pi plans
7 pi plans [message #74437] Sun, 11 November 2012 11:24 Go to next message
JeffreySmith is currently offline  JeffreySmith
Hi, could I get the plans to the 7 pi?
Also, what is included in the kit? I noticed that you sell a midhorn flatpack -- I'm guessing that they are not part of the kit.
Are they necessary? I have no woodworking experience, so if the only other way to get them is by building them myself I'll happily buy the flatpack.
Re: 7 pi plans [message #74438 is a reply to message #74437] Sun, 11 November 2012 12:20 Go to previous message
You've got mail!
Kits include the speaker drivers, the connector panel, hook up wires, "π" logo decal and a printed copy of the plans. For larger speakers that incorporate a compression tweeter and crossover network, kits also include the crossover, Zobel woofer damper, and all cable assemblies are completed and ready to install. Every kit containing a compression driver also includes the horn flare and the bolts to mount the driver to the horn.
The midhorn flatpack kit can be purchased separately. You can build it yourself if you are comfortable with the angles. Make one out of cardboard first, and you'll get an idea what's required. It isn't a terribly hard horn to build, but we make the flatpack kit to make it even easier.
Previous Topic: 4PI Break In
Next Topic: Speakers for flea powered amp
Current Time: Sat Oct 24 17:05:00 CDT 2026
