Home » Sponsored » Pi Speakers » Why mount crossover components to separate board?
Why mount crossover components to separate board? [message #73769] Mon, 10 September 2012 12:10 Go to next message
Silas is currently offline  Silas
What is the reason behind mounting the crossover components to a board, and then mounting the board to the cabinet? Couldn't I just mount the components to the cabinet directly, a la below?
http://i464.photobucket.com/albums/rr10/FrostyPanda/P10001542.jpg
Re: Why mount crossover components to separate board? [message #73770 is a reply to message #73769] Mon, 10 September 2012 16:31 Go to previous messageGo to next message
The board just makes it easier... Easier to do the x-over build and use the soldering iron. I like to use a 1/4" piece of something that I can drill holes in. Zip tie on Caps, Inducers since they are heavy... Goop em with silicone...
You can do what you are thinking direct and not use a board.
Re: Why mount crossover components to separate board? [message #73771 is a reply to message #73770] Mon, 10 September 2012 16:33 Go to previous messageGo to next message
PS - I see 5 larger resistors in the middle. Are these the 100W spot? What are these?
Re: Why mount crossover components to separate board? [message #73775 is a reply to message #73771] Tue, 11 September 2012 03:36 Go to previous messageGo to next message
mantha3 wrote on Mon, 10 September 2012 16:33
Those are 5 20W, 40R resistors, to be wired in parallel to achieve 100W at 8R.
Re: Why mount crossover components to separate board? [message #73776 is a reply to message #73775] Tue, 11 September 2012 07:55 Go to previous messageGo to next message
Ahhh, that is what I was thinking.
I did notice in the X-Over schematic by Wayne it mentions that this resistor R3 is "Mounted off board". Is this due to heat or something?
I'm going to be building soon and the X Over is something I'll do soon. Doing the 5 resistors like you will save some $$$ so I think I'll copy you on this.
Keep posting build stuff/photos. I'll do the same.
Re: Why mount crossover components to separate board? [message #73778 is a reply to message #73776] Tue, 11 September 2012 12:18 Go to previous messageGo to next message
Will do. I'm actually keeping a build thread on AVS, titled something like "JBL and 4Pi theater...college style!" I won't link to it, but you can search for it if you like. PM me if you have any questions.
Re: Why mount crossover components to separate board? [message #73806 is a reply to message #73776] Wed, 12 September 2012 23:32 Go to previous messageGo to next message
Sorry I missed this earlier:
mantha3 wrote on Tue, 11 September 2012 07:55
The R3 Zobel resistor we provide in the kits is packaged in a large aluminum block which serves both as a heat sink dissipator and as a mounting block. Our crossover PCB has a connector for this resistor, which is mounted off-board. We mount the crossover and Zobel resistor on the inside of the cabinet, directly on the bottom using a gasket to prevent vibration.
Re: Why mount crossover components to separate board? [message #73807 is a reply to message #73806] Thu, 13 September 2012 07:33 Go to previous messageGo to next message
Would you worry about heat issues using 5 of these 20W 40R resistors?
Re: Why mount crossover components to separate board? [message #73808 is a reply to message #73807] Thu, 13 September 2012 08:19 Go to previous message
The dissipation capacity is rated the same, so I would expect performance to be the same.
Previous Topic: 4Pi stand height for home theater usage
Next Topic: 7pi plans, please
Current Time: Sat Oct 24 17:01:26 CDT 2026
